Quello che vorrei fare è riuscire a lanciare NetBeans direttamente dal menù del desktop (o dal desktop, andrebbe bene lo stesso), nella sezione "programming" dove ci sono code::blocks, BlueJ, Geany e tutto il resto.
Qualcuno saprebbe indicarmi come fare?
Ringrazio anticipatamente.
Edit:
Lo script netbeans è un file senza estensione e questo è il suo contenuto
- Codice: Seleziona tutto
#!/bin/sh
# DO NOT ALTER OR REMOVE COPYRIGHT NOTICES OR THIS HEADER.
# Copyright 1997-2016 Oracle and/or its affiliates. All rights reserved.
# Oracle and Java are registered trademarks of Oracle and/or its affiliates.
# Other names may be trademarks of their respective owners.
# The contents of this file are subject to the terms of either the GNU
# General Public License Version 2 only ("GPL") or the Common
# Development and Distribution License("CDDL") (collectively, the
# "License"). You may not use this file except in compliance with the
# License. You can obtain a copy of the License at
# http://www.netbeans.org/cddl-gplv2.html
# or nbbuild/licenses/CDDL-GPL-2-CP. See the License for the
# specific language governing permissions and limitations under the
# License. When distributing the software, include this License Header
# Notice in each file and include the License file at
# nbbuild/licenses/CDDL-GPL-2-CP. Oracle designates this
# particular file as subject to the "Classpath" exception as provided
# by Oracle in the GPL Version 2 section of the License file that
# accompanied this code. If applicable, add the following below the
# License Header, with the fields enclosed by brackets [] replaced by
# your own identifying information:
# "Portions Copyrighted [year] [name of copyright owner]"
# Contributor(s):
# The Original Software is NetBeans. The Initial Developer of the Original
# Software is Sun Microsystems, Inc. Portions Copyright 1997-2007 Sun
# Microsystems, Inc. All Rights Reserved.
# If you wish your version of this file to be governed by only the CDDL
# or only the GPL Version 2, indicate your decision by adding
# "[Contributor] elects to include this software in this distribution
# under the [CDDL or GPL Version 2] license." If you do not indicate a
# single choice of license, a recipient has the option to distribute
# your version of this file under either the CDDL, the GPL Version 2 or
# to extend the choice of license to its licensees as provided above.
# However, if you add GPL Version 2 code and therefore, elected the GPL
# Version 2 license, then the option applies only if the new code is
# made subject to such option by the copyright holder.
# resolve symlinks
PRG=$0
while [ -h "$PRG" ]; do
ls=`ls -ld "$PRG"`
link=`expr "$ls" : '^.*-> \(.*\)$' 2>/dev/null`
if expr "$link" : '^/' 2> /dev/null >/dev/null; then
PRG="$link"
else
PRG="`dirname "$PRG"`/$link"
fi
done
progdir=`dirname "$PRG"`
old=`pwd`
cd "$progdir"/..
basedir=`pwd`
cd "$old"
case "`uname`" in
Darwin*)
# set default userdir and cachedir on Mac OS X
DEFAULT_USERDIR_ROOT="${HOME}/Library/Application Support/NetBeans"
DEFAULT_CACHEDIR_ROOT=${HOME}/Library/Caches/NetBeans
# set default userdir and cachedir on unix systems
DEFAULT_USERDIR_ROOT=${HOME}/.netbeans
DEFAULT_CACHEDIR_ROOT=${HOME}/.cache/netbeans
esac
if [ -f "$basedir"/etc/netbeans.conf ] ; then
. "$basedir"/etc/netbeans.conf
fi
# following should be done just in RPM or Solaris Launcher
# if [ -f /etc/netbeans.conf ] ; then
# . /etc/netbeans.conf
# fi
export DEFAULT_USERDIR_ROOT
# #68373: look for userdir, but do not modify "$@"
userdir="${netbeans_default_userdir}"
cachedir="${netbeans_default_cachedir}"
founduserdir=""
for opt in "$@"; do
if [ "${founduserdir}" = "yes" ]; then
userdir="$opt"
break
elif [ "$opt" = "--userdir" ]; then
founduserdir="yes"
fi
done
foundcachedir=""
for opt in "$@"; do
if [ "${foundcachedir}" = "yes" ]; then
cachedir="$opt"
break
elif [ "$opt" = "--cachedir" ]; then
foundcachedir="yes"
fi
done
if [ -f "${userdir}"/etc/netbeans.conf ] ; then
. "${userdir}"/etc/netbeans.conf
fi
if [ ! -f "$basedir"/etc/netbeans.clusters ]; then
echo Cannot read cluster file: "$basedir"/etc/netbeans.clusters 1>&2
exit 1
fi
readClusters() {
grep -v "^#" "$basedir"/etc/netbeans.clusters | grep -v "^$" | grep -v platform | while read X; do
if expr "$X" : "/.*" >/dev/null; then
echo "$X"
else
echo "$basedir/$X"
fi
done
absolutize_paths() {
while read path; do
if [ -d "$path" ]; then
(cd "$path" 2>/dev/null && pwd)
else
echo "$path"
fi
done
netbeans_clusters=`readClusters | absolutize_paths | tr '\012' ':'`
if [ ! -z "$netbeans_extraclusters" ] ; then
netbeans_clusters="$netbeans_clusters:$netbeans_extraclusters"
fi
heap_size () {
mem=640
case "`uname`" in
Linux*)
mem=`cat /proc/meminfo | grep MemTotal | tr -d [:space:][:alpha:]:`
mem=`expr $mem / 1024`
SunOS*)
mem=`/usr/sbin/prtconf | grep Memory | /usr/bin/tr -dc '[0-9]'`
Darwin*)
mem=`/usr/sbin/sysctl hw.memsize | tr -d [:alpha:][:space:].:`
mem=`expr $mem / 1048576`
esac
if [ -z "$mem" ] ; then
mem=640
fi
mem=`expr $mem / 5`
if [ $mem -gt 1024 ] ; then
mem=1024
elif [ $mem -lt 96 ] ; then
mem=96
fi
max_heap_size=$mem
return 0
if grep -v -- "-J-Xmx" >/dev/null <<EOF ; then
${netbeans_default_options}
EOF
heap_size
netbeans_default_options="-J-Xmx${max_heap_size}m ${netbeans_default_options}"
fi
launchNbexec() {
nbexec=`grep -v "^#" "$basedir"/etc/netbeans.clusters | grep -v "^$" | grep platform | while read X; do
echo $X/lib/nbexec
elif [ -f "$basedir"/$X/lib/nbexec ]; then
echo "$basedir"/$X/lib/nbexec
fi
done | head -n 1`
sh=sh
# #73162: Ubuntu uses the ancient Bourne shell, which does not implement trap well.
if [ -x /bin/bash ]
then
sh=/bin/bash
fi
exec $sh "$nbexec" "$@"
else
exec $sh "$nbexec" --userdir "${userdir}" "$@"
else
exec $sh "$nbexec" --userdir "${userdir}" --cachedir "${cachedir}" "$@"
fi
fi
# in case of macosx, the apple.laf.useScreenMenuBar property should be ideally in the Info.plist file
# but it doesn't get propagated into the executed java VM.
case "`uname`" in
Darwin*)
eval launchNbexec \
--jdkhome '"$netbeans_jdkhome"' \
-J-Xdock:name=NetBeans \
'"-J-Xdock:icon=$basedir/nb/netbeans.icns"' \
--branding nb \
--clusters '"$netbeans_clusters"' \
-J-Dnetbeans.importclass=org.netbeans.upgrade.AutoUpgrade \
-J-Dnetbeans.accept_license_class=org.netbeans.license.AcceptLicense \
${netbeans_default_options} \
eval launchNbexec \
--branding nb \
esac
