VCA810 Can’t Magnify
Moderatori: Foto Utentecarloc, Foto Utenteg.schgor, Foto UtenteIsidoroKZ, Foto UtenteBrunoValente
[1] VCA810 Can’t Magnify
Messaggioda Foto Utenteethiopia » 17 mag 2017, 9:52
Hello~all :-)
Recently I am involving in a project about VCA810(this is its data-sheet: http://www.kynix.com/uploadfiles/pdf9675/VCA810AID.pdf ). I met some troubles and I hope someone here can help me out.
My schematic diagram is given below. Please have a look whether there are some wrongs. Thank you in advance.
My VCA810 can realize the attenuation of -40DB when the controlling voltage is between -1V and 0V. However when the voltage is between -1V and -2V, it can’t magnify and there are no signals.
How to solve such problems? Can you?
Best wishes~
Foto Utenteethiopia
[2] Re: VCA810 Can’t Magnify
Messaggioda Foto UtentePietroBaima » 17 mag 2017, 11:54
Hello and welcome onboard. :D
Unfortunately your image is not reachable, hence I am afraid it will be hard for you getting an answer.
Can you please fix the attachment for me?
Thanks
nomi
emoticon
citazioni
formule latex
82,6k 7 12 13
[3] Re: VCA810 Can’t Magnify
Messaggioda Foto Utentesimo85 » 17 mag 2017, 12:02
Ops, Pietro, I attached the image while you were writing your message.
I didn't see it. Sorry.
Maybe the OP will start use Fidocadj next time. :-)
Foto Utentesimo85
30,8k 7 12 13
Disattivato su sua richiesta
[4] Re: VCA810 Can’t Magnify
Messaggioda Foto UtentePietroBaima » 17 mag 2017, 12:06
No worries, indeed, thanks!
nomi
emoticon
citazioni
formule latex
82,6k 7 12 13
[5] Re: VCA810 Can’t Magnify
Messaggioda Foto Utenteboiler » 17 mag 2017, 12:42
According to your schematic, you swapped the positive and the negative supply.
Cheers, Boiler
Foto Utenteboiler
18,0k 5 7 13
[6] Re: VCA810 Can’t Magnify
Messaggioda Foto Utentelelerelele » 17 mag 2017, 12:56
Hi Foto Utenteethiopia
Sorry in advance for my bad english!
I not know this IC, but try to make a solution.
Why input signal on +input? this are offset? if this offset are 1mV (for example) what are the +40dB output of this?
said this, output pin can saturate? What are voltage Dc out of this?
for me problem can here.
bye.
2.662 3 7 9
[7] Re: VCA810 Can’t Magnify
Messaggioda Foto UtenteMarcoD » 17 mag 2017, 13:26
Dear Foto Utenteethiopia,
your electric drawing appears to be correct referring to the data sheet.
How do you set the Vcontrol ? In figure 47 they advise to insert an RC lowpass filter, but it is not mandatory.
About the Vc I have understood:
VC = 0 V -40 dB attenuation X100
VC = -1 V 0 dB gain X1
VC = -2 V 40 dB gain X100
ciao
Foto UtenteMarcoD
8.446 4 9 13
[8] Re: VCA810 Can’t Magnify
Messaggioda Foto Utenteboiler » 17 mag 2017, 13:36
MarcoD ha scritto:your electric drawing appears to be correct referring to the data sheet.
No, it doesn't:
Cheers, Boiler
Foto Utenteboiler
18,0k 5 7 13
[9] Re: VCA810 Can’t Magnify
Messaggioda Foto Utenteboiler » 17 mag 2017, 13:38
Another question: why are you talking about the VCA810 while your schematic is built around a VCA821?
Foto Utenteboiler
18,0k 5 7 13
Visitano il forum: Google Adsense [Bot] e 53 ospiti
